TwinTurbo.NET: Nissan 300ZX forum - Thermostat is good. I had bought one from AutoZone
Subject Thermostat is good. I had bought one from AutoZone
Posted by Worm Boy on February 20, 2011 at 7:39 PM
  This message has been viewed 180 times.
In Reply To Check the thermostat it may not be opening full stroke. posted by ZUL8TR on February 20, 2011 at 07:27 AM
Message and then got an OEM because I thought the AutoZone thermostat could have been bad. I did do the stove top procedure to get it to open up and it's working properly. I haven't done a radiator flush, I don't have any debris, leaves, etc. between radiator and AC condensor.
Fan clutch is operating properly, and electric fans turn on after awhile of running my A/C. I'll try and do a radiator flush and make sure I have no air in the system and for NJZ, I have tested the ohms on the temp sensor.
What I don't underrstand how is it that the sensor is reading correctly and reading 203 degrees? Wouldn't it be reading what ever temperature is in the radiator even if it's not submerged in coolant?
